WiFi connection does not work with a battery on Espruino WiFi. #1000
Replies: 3 comments
Posted at 2018-10-06 by Robin Sat 2018.10.06 Hello @juancar. There are many 'onInit' functions and 'quick start' examples.
Would you please post the http: link as seen in the browser so we are able to follow along. > 'but when I disconnect it and plug it to a battery of 3.7volts using pin + and - the wifi connection fail.' Do we know if this is a software issue or a hardware one? What is the voltage measured at the 3.3v pin adjacent to the VUSB + pin? This will show if the battery has sufficient voltage to allow the on-board regulator to function correctly. Is the Espruino Wifi being recognized by other devices such as your PC or phone? Do they detect by name in their list of available recognized devices? Was the code saved |
Beta Was this translation helpful? Give feedback.
Posted at 2018-10-07 by JuanCar Hi Robin, thanks a lot for your fast support. I found the problem after deep reading of the manuals. My problem was to use setDeepSleep(1) before finish the wifi connection. I had this code: If I write setDeepSleep(1) just after LED2.on() everything is working. I would not say it is a bug frimware, it is a bad programming. I came acrros with this solution when I read setDeepSleep does not work with USB PC connection. Thanks a lot for your help! |
Posted at 2018-10-08 by @gfwilliams Great, glad you got it sorted! Unfortunately the issue is that on STM32, Deep Sleep is less of an issue with WiFi on since the WiFi module draws so much more power than the STM32 does. Realistically the best thing to do is to only enable deep sleep when the WiFi is off, and to disable it when it is on. |
Uh oh!
There was an error while loading. Please reload this page.
Posted at 2018-10-06 by JuanCar
Hi +Gordon, hi all.
I am have a Espruino WiFi 1.1 running frimware 1v99. I just trying to connect to a wifi home network and it is working when the board it is pluged to the computer, but when I disconnect it and plug it to a battery of 3.7volts using pin + and - the wifi connection fail.
The code is unther the onInit fuction as the quick start example.
Does anybody had this fail before?
All reactions
